I posted in classifieds but there seems to be no way to insert an image there. In the mean time these are what I need Shouldered washers for gen1 for windshield screws 1 or 2 needed, and fairing mounting screws, the bigger ones, 3 or 4 needed.
Sooner the better.
Thanks.
I do see them there. I brought these to Yamaha today, and Rice to see if they had universals and no go on that but I could get them straight from Yamaha for around $7 each if I order them. I was really hoping someone had a parts bike laying around with these still on it. the OP put it together having lost a few of these. It looks like the collar in one of those pics.
Ummm you should see what else you might need and order them from partzilla or something, because even on the Yamahapartshouse.com they arent even close to 7 bux a piece....
I'm pretty sure the bike needs nothing else. As soon as I get the serial cable for the Ignitek I should be ready to roll this pig, I already put the money and work into her. I should be ready for the international ralley with no further fussing (I hope).
funny thing I ordered some of those earlier today, so I figured I would get the other screws I needed and an airbox intake tube for the honda. So yeah just little odds and ends the shipping tho, was almost as much as I paid for the screws,spring washers, and special shape screws. Put on another 100 miles today...
My local tractor supply has odds and ends like that in hardware section. So does my lowes in the "special hardware" cabinets.
This thread is not a problem but I just wanted to say that you can post pictures in the classifieds. The boxes are right there when you create the ad. Not sure why you had a problem. Just posting this as information.
I found the function to insert link or image, so I clicked insert image and a box popped up asking for source, a box in which I had to type something and I had no idea what that meant or what to do with. I couldnt find an image system like what we use to post images in the conversational threads.
Thank you for the leniency on this, I promise not to beat it to death. If nobody has a few of these loose I'll order new or most likely make some.
That is true if you try to add the image after you've already posted the ad. If you do it while you are initially creating the post though, you just click "insert" and it opens up your computer folders so you can select an image to upload just like you do here.
