cimmer Posted March 20, 2017 Posted March 20, 2017 One of the things you need to do when wet checking is to get the bike on the center stand and then use a jack to make sure the carbs are level. This most likely means jacking the bike up a bit in the front. If you have the service manual, I am seeing a description on the procedure on page 5-9 of the 86-93 Venture service manual. It also states the open the drain tube with the tube attached and warm up the engine. It doesnt really say, but I am wondering if you need to take the measurement with the engine idling so that you see the float and needle working to maintain the correct level? If I need to do this I think I would make marks on a clear tube for the center line of the slider and the level desired for the fuel to be at. Keep up informed of your progress if you would.. Thanks Rick F.
Javenmcd Posted March 20, 2017 Author Posted March 20, 2017 Hi Rick....I made sure the engine was level side to side and front to back...checked at idle and while not running.. I doubt I'll have any more updates for you...I gave up.
cimmer Posted March 21, 2017 Posted March 21, 2017 Sorry to hear you gave up on it but I totally understand.. some times it is the best thing for our sanity in the long run. Rick F.
cecdoo Posted March 21, 2017 Posted March 21, 2017 Hate to see you give up, one guy on here just posted about parting out a 1st gen, have you given any thought to swapping out the whole carb set. Hell as many times as you have done it already its probably only a 10 min job for you. Take a break for a week or two and then give it another shot. All the best, Craig
