turtle Posted February 28, 2017 Posted February 28, 2017 I was wondering if I could tow my wife's 93 Goldwing trike by the front wheel behind a truck out of gear . I think I can make a nice cradle lift to go into a receiver but don't know if it will hurt motor or transmission. Any thoughts?
Motorcycle Mike Posted March 1, 2017 Posted March 1, 2017 Everything I've ever heard says it will damage the transmission. Trailers are relatively inexpensive. Certainly a lot cheaper than a new tranny.
snyper316 Posted March 1, 2017 Posted March 1, 2017 on cars hooked to tow dolly I have always removed the drive shaft, now being a motorcycle I don;t believe that it is that easy to do....
Flyinfool Posted March 1, 2017 Posted March 1, 2017 I guess that it all depends on if there is pressurized oil being supplied to any part of the transmission, if it is just gears running in the sump the trans will not know if the engine is running or not. Cars with manual transmissions can be towed in neutral just fine, it is the automatic transmissions that can not be towed because the bearings are lubed by ATF fluid under pressure. I do not know anything about the lubrication system in a wing.
Mike G in SC Posted March 3, 2017 Posted March 3, 2017 We're going from SC to Redwing, MN for STAR Days in July. Would love to ride, but too hot for the wife, so we will trailer our GW Trike.
Jayceesfolly Posted March 4, 2017 Posted March 4, 2017 I think I would be concerned about the high angle the front wheel and forks would be setting at if the wheel was 18 to 24 inches off the ground. Seems to me that there would be a lot of stress put on the forks. Are the forks strong enough to absorb the stresses of bouncing the rear of the bike in and out of potholes and over RR tracks, gas station curbs, etc., at that odd angle? Food for thought. I think I would rent or buy a trailer. Jim
