bongobobny Posted February 17, 2017 #1 Posted February 17, 2017 While looking at the schematic for the fuel pump relay on the '83 model only, I discovered that the fuel pumps on that year only do NOT shut off after the initial few seconds before the bike starts!!! That safety feature was not incorporated until the '84 on up models!!! So, if you own an '83 your fuel pump should keep clicking and clicking until the fuel bowls are up to full pressure!! I'm sure there is a reason for that safety feature being added after '84, I always assumed it was to prevent the possibility of getting a hydro lock from too much fuel pressure, or in the case of a stuck needle valve staying open. Anyway, the gray line from the number 2 coil trigger from the TCI that also feeds the tach is what restores the fuel pump relay. On the '83 there is no gray wire to the relay, just a duplicate R/W line. That relay is a special relay that has a "Time constant" circuit in it that makes it run initially for a few seconds when the bike is first turned on... Just wanted to pass this on!
Yammer Dan Posted February 17, 2017 #2 Posted February 17, 2017 I somehow knew that. Have pumped fuel into a container from 83. Tried it on 85 and it shut down. But didn't think it out. Got what I wanted at the time done so.....
snyper316 Posted February 17, 2017 #3 Posted February 17, 2017 No wonder mike is a kick butt rocking machine it dont shut up lmao!!!
snyper316 Posted February 17, 2017 #4 Posted February 17, 2017 I will have to definately try this theory. I am thinking mine does shut off after a couple of clicks. Because when I had my carbs off I forgot about the gas still being on and it only pumped a few seconds but after I realized what I did I turned the key back off... So I will test this in the morning by hooking hose to outlet and stick it in gas can just to see...
bongobobny Posted February 17, 2017 Author #5 Posted February 17, 2017 Just keep in mind as soon as the system reaches full pressure the pump can't pump anymore so it will stop clicking. 12 volts will still appear across the pump, though...
Venturous Randy Posted February 17, 2017 #6 Posted February 17, 2017 My 83 will click for a few seconds when I turn the key on and I will then flip the kill switch off and on and it will again click for a few seconds. If I will keep repeating this, mine will start to click less and less until it stops. So, if what you say is correct and I understand it right, my 83 works like an 84 and up. Randy
snyper316 Posted February 17, 2017 #7 Posted February 17, 2017 Venturous only if we hook up a different fuel pump..... the one we have has the built in safety features, just the relay keeps running. I have a fuel pump somewhere I could try.. If I can remember what I did with it. But it was off of a chevy luv I had...
Marcarl Posted February 17, 2017 #8 Posted February 17, 2017 I think basically the fuel pumps all run the same. It's a spring and solenoid setup. The solenoid draws the shaft one way, then shuts off by the limit switch, a spring draws it back to the starting point and the cycle starts again. The spring stroke provides the pumping and pressure. The relay is there just to limit the time of running when the bike is not running.
Flyinfool Posted February 17, 2017 #9 Posted February 17, 2017 Or is it possible that the 2 second feature was added during the 83 model year.
Condor Posted February 17, 2017 #10 Posted February 17, 2017 Or is it possible that the 2 second feature was added during the 83 model year. That's my thinking as well. I consider the '83 as a BETA model, with small tweeking changes made during production. Even the '84 occasionally. I.E. the choke set being '84 only...
GaryZ Posted February 17, 2017 #11 Posted February 17, 2017 Electric fuel pumps will automatically shut off when the preset back pressure is reached. I think the manufacturers want the fuel to shut off in case of an accident. the fuel pump is allowed to run for only a few seconds, when the key is first turned on, to pump fuel into the carbs. The electric pump can constantly run when the engine is running. My Ninja has the same thing. All cars with electric fuel pump will have the same feature. BTW: To test the electric fuel pump in a car or bike the fuel pump relay is bypassed. Both of my Ninjas are permanently bypassed because I couldn't figure out why they would not work. They have been bypassed for years
bongobobny Posted February 17, 2017 Author #12 Posted February 17, 2017 Or is it possible that the 2 second feature was added during the 83 model year.That is quite possible, I am just going by the factory wiring diagrams for the '83 versus the '84. Go to the Technical Library and view the schematics at the fuel pump. On the '83 the R/W wire goes to two places on the relay whereas on the '84 the gray line from the TCI goes to the one connection...
