Some info, I found oil leak on my bike, suspected drain plug, not.
It is the neutral safety switch. It has small cracks spidering out from mounting screws. Removed and found 2 cracks extends under seal.
Ordering new switch and seal. Buy the way you will need new middle gear cover seal, since it has to be removed to access switch.
Was following thread on 2nd Gen Tech Talk, oil leak freak out, his pictures of his leak looked just like mine.
Hope this helps someone, this site has been of great value to me.
