Why would they put an idiot light for the oil level when there already is a window to check it? The light came on today after I gassed up.
If I can't find a replacement I might just cut the wire going to it!!
(BTW the oil level was fine and is fresh.) :bang head:
If the oil level light doesnt come on under acceleration you arent riding it hard enough lol. They must have thought consumption might be an issue.
Sent from my SCH-I535 using Tapatalk
The oil sight glass only works when the bike is on the center stand. The Venture is a deluxe touring bike and lifting it onto the center stand is difficult enough empty but lifting a fully loaded one would be next to impossible. If the oil warning comes on under hard acceleration or when going up a hill then it is time to check the level. It is one of the many perks that comes with a superiour touring machine.
There is a float switch inside the case that can get clogged. (Thanks Puc. :bowdown:) Check the connections first to see if there is an electrical issue.
