Working on a friend's 89 and did the battery bypass with the resistor as I did years ago on my 83 (worked great on my 83). Battery icon and red flashing light are still active. Am I missing something here? I tried several values of resistor from 1k to 22k ohms. Is there a way to deactivate this right on the circuit board? I found this bike with the sensor already removed from the end of the wire so I am thinking the PO probably tried to do something here, I'm just not sure what.
Well Stan, a couple of possibilities. You could try the resistor mod at the CMU end of the White/red wire, eliminating possibility of there being an open on that line. Second, remove the CMU and resolder the edge connector as there may be a bad (open) solder connection there. Third, maybe the PO tied the W/R wire directly to 12 volts and blew out the monitor input for that...
Piece of black electrical tape over that rotten little flashing red light Stang!!!
Sorry brother,, couldnt resist,,, best to be following Bongo!!!
