ReinyRooster Posted September 20, 2016 #1 Posted September 20, 2016 One of the first things I am going to do in an attempt to reduce/eliminate handlebar vibration is to install bumpers between the lower wind deflectors and the forks. Are these something pre-made that you can buy or are people making their own? Would love to see pics if anyone has any. thanks
Freebird Posted September 20, 2016 #2 Posted September 20, 2016 The come from the factory with rubber bumpers. Sometimes the brackets need to be bent back a bit so that they make contact. If they are missing, there are a number of ways to make new ones. I use rubber expanding nuts with the brass threaded inserts. Just put a screw through the hole and into the rubber expansion nut. I have pictures here somewhere if I can find them.
Freebird Posted September 20, 2016 #3 Posted September 20, 2016 Here you go. http://www.venturerider.org/forum/showthread.php?119676-Lower-wind-deflectors
crowrod Posted September 20, 2016 #4 Posted September 20, 2016 here you go , Damper 2 5A8-21639-00-00 $2.60 each
vzuden Posted September 20, 2016 #6 Posted September 20, 2016 If, however, you have passing lamps and then have a relocation bracket added to move the passing lamps away from the fairing allowing easier splitting of the fairing you will need longer bumpers than shown. I installed some stainless bolts and added rubber bumpers found at the hardware store to the ends of the bolts. I believe I modified them slightly and maybe just drilled a hole in the rubber before I glued them on. As stated they need to contact the fork covers and the bolts allowed some adjustment by varying the length via the depth inserted into the rubber
