Does anyone know if the clutch cover from an 85 will fit onto my 88?
The part numbers are similar the '85 is 26H-15431-01-00 and the '88 is 1NL-15341-00-00.
I do not care about the markings or emblems, just the mechanical fit.
A 1200 cover will not fit a 1300 motor. They are different overall width due to clutch spring differences.
Gary
If it is just for clearance of the clutch spring, then maybe I can make it work.
Now I have to wonder, I was planning to cut the middle of it out to put in a window so a clutch spring clearance issue may go away.
I have an early 85 disassembled engine sitting in the basement with a bad 2nd gear.
So if I ever have to replace the cover I guess mine would stick out more? Or would it be a larger circumfrance?
The extra height of the MKII clutch covers isn't noticeable. The foot prints are the same, and take the oem fasteners. Personally I'd pick one up off eBay....
