Hi guys, I have an 86 Royale . The class system was showing E4....solved that by resoldering the nine pins at the back of the plug. Now I have an E1 fault code.... How do I cure this one please....?
Thanks in advance...
Regards
Kevin
Regards
Kevin
"E1" error may encompass a broad range of defects.
  • Faulty connections.
  • Faulty discharge valve (solenoid).
  • Low pressure sensor input voltage. (Low battery or low voltage due to poor connectors)
  • Faulty pressure sensor.
  • And finally, incomplete solder repair at the nine pin board connector.
Regards
Kevin
Same issue with my 86, ended up changing the compressor assembly. About a year later I removed the system and added schrader valves and bought a portable 12v compressor from Harbor Freight for $9.00 and never looked back. and I can air up my tires if needed.:2cents:
