No low fuel light
Took the sender out yesterday. It appears by "per the manual testing" the sending "dohicky" is kaput. No light, no "count up" trip meter.
Anyone know of an off the shelf replacement? Doesn't look like it would be hard to change with a bit of soldering.
It's the metal can at he bottom of the sender assembly it has holes in the end I'll assume; some sort of capacitance measuring circuit.
Watching for a cheap "used assembly" on fleabay but......
No low fuel light
I'm in the same boat? Replaced bulb but still no light or trip odo count. All I get is the motor stumble... Which switching to reserve cures.
From what I've read in older posts, replacing sender unit is easy and not that expensive. Next time my tank is low, I'll take it off and see if I can fix something.
