Looking at wiring schemail for 99 venture. It shows a fuse between the fuel indicator and rectifier... Kind of weird.. anyone know where it is? Maybe this will fix my gauge that is flashing from both ends...
Besides the main fuse, there are two fuse blocks, both on the right side of the bike. One is under the false battery cover, and the other is inside the lower fairing...
Hope that helps!
Fuel gauge segments flashing are probably a faulty code, I know when the sending unit goes bad it flashes a code using the gauge segments.
Watch them to see if there is a pattern, like a few flashes then pause and then 2 or 3 more flashes, those codes are in the repair manual in the troubleshooting section.
