bikerjohn Posted April 16, 2008 Posted April 16, 2008 My passing lights and my Sebler horn are both out! With the passing lights I hear the soleniod click when I push the switch, but they do not come on! Any ideas on what could be the issue. I checked all fuses and they all look great. The passing lights are power off the front receptical and the horn is power from the circuit going to the rear receptical (if I had one). Any ideas or thought would be great. Thanks BikerJohn
99silver Posted April 16, 2008 Posted April 16, 2008 John, You should run the horn off the battery with a relay. Gary
V7Goose Posted April 17, 2008 Posted April 17, 2008 Neither of those circuits you used are sufficient for the load you hooked up to them. You popped the 5 amp fuses. Passing lights and horns need a minimum of 10 amp circuit. Do not just increase the fuse size - you will melt the wires and burn up your bike. Goose
