Lug Nut Posted August 26, 2016 #1 Posted August 26, 2016 Was setting warm idle with EZ Tach today....and hooked up Morgan Carbtune to sync the carbs. While adjusting idea ibwas really listening to exhaust. Bike is all mechanically stock, changed every fluid/filter/plugs etc. 43k miles. Runs great. I do get popping on decel with stock carb/air box and filyer/pipes. Ibwas thinking I may need to tweak pms. What is the stock setting for this bike? 1.5 - 2 turns out? Thanks...
camos Posted August 26, 2016 #2 Posted August 26, 2016 Ibwas thinking I may need to tweak pms. What is the stock setting for this bike? 1.5 - 2 turns out? I didn't know there was an adjustment for PMS... ... but if you are referring to the idle jet adjustment the place to start is 2 1/2 turns out.
Guest Jamsie Posted August 26, 2016 #3 Posted August 26, 2016 if only you could set PMS to zero fortunately the wife is past all that , its the hot flushes nowadays
WildBill1 Posted August 26, 2016 #4 Posted August 26, 2016 PMS huh, oh Lug Nut you need too take a long ride like 5 or 10 years just call in every once in awhile.
Lug Nut Posted August 26, 2016 Author #5 Posted August 26, 2016 Got it all adjusted 2.5 turns out and carbs synced.....worked out great....thanks.
