Mordalo Posted April 16, 2008 #1 Posted April 16, 2008 Greetings oh knowledgeable ones... I was wondering if anyone knows whether or not the Fender ornament on my 99 RSV is a Yamaha ornament. More importantly, does anyone know where I can get a replacement rubber base for it? The one on this ornament is rotting and cracked. Thanks in advance!
Freebird Posted April 16, 2008 #2 Posted April 16, 2008 No, that is not a stock Yamaha item. I've seen those in several catalogs and on Ebay but I'm not sure who makes it.
mike_kelly_68 Posted April 16, 2008 #4 Posted April 16, 2008 Looks to me like a clearance light from a truck
KiteSquid Posted April 16, 2008 #5 Posted April 16, 2008 NOPE, it is a finder lamp from an old Harley. I have one on my 1950 FL. Look in the Harley aftermarket catalogs....for reproductions. You might remove it and look inside it for some manufacturer's identifying marks.
Mordalo Posted April 17, 2008 Author #6 Posted April 17, 2008 Huh... you know it never occurred to me to me to take it off and look inside... that's why I'm always asking the questions instead of answering 'em. Thanks!
whozleft Posted April 18, 2008 #7 Posted April 18, 2008 If you want a rubber base what would you think about buying a cheap mouse pad, taking the ornament off, and using it as a pattern to cut a new rubber base out of the mouse pad? On another forum I read where a guy made a laydown license plate bracket and used a rubber mouse pad as a base between the fender and bracket. It's just a thought, would be cheap and could be replaced easily.
Mordalo Posted April 18, 2008 Author #8 Posted April 18, 2008 It might be a challenge trying to get a clean edge just because my aim ain't so good with a razor blade and that ornament is a pretty major focal point (I get a lot of comments on it) but if I can't find anything else (already checked e-bay... no joy) I'll certainly give that a shot (and in line with the forum 'rules' I will take pictures and post the results). Thanks for the suggestion. Even if I don't use it on this particular project I may use that elsewhere. Like to make a new windshield seal for instance. Was working on buffing out the scratches on my windshield to day (which didn't go as well as I had hoped) and noticed that the weather seal was pretty shot there as well. This fine desert sun is beautiful at sunset here in New Mexico but it stays that way by feeding on paint and rubber. Thanks for the suggestion!
SteveW Posted April 18, 2008 #9 Posted April 18, 2008 I have the same light that came on my sidecar fender. You might try the Champion sidecar site or I'm pretty sure I have seen them at a Harley shop.
Mordalo Posted April 19, 2008 Author #10 Posted April 19, 2008 So y'all were correct. It's an old Harley ornament from the '30's I only found 1 web site (well, I found a few, but only 1 in english) that has it (http://www.american-made.com/midusa/pages/frames/frontfenders.htm) for $10!! ironically, they're charging $12 for S&H. I think I'm going to go ahead and order it anyway simply because it really does look bad-a$$. I get a lot of comments on it. Thanks again all!!
