Mad Dog Posted August 1, 2016 #1 Posted August 1, 2016 Cant find them if they are here, so does anyone have any instructions or comments on lowering a 2006 RSV? I have done a back tire myself, so I think thats going to be pretty much almost the same?? TIA Mike
Freebird Posted August 1, 2016 #2 Posted August 1, 2016 Are you wanting to lower the front, back or both? Here are some basic instructions on lowering the front: http://www.venturerider.org/forum/showthread.php?939-Lowering-the-Front-End Now here are some instructions for RAISING the rear. Lowering would be pretty much the same process except you would need longer links instead of shorter. You will also need a caliper relocating kit. The only one that I know of is made by Baron's. It comes with the links and the relocation bracket for the caliper. Installation would be the same as this thread. http://www.venturerider.org/forum/showthread.php?492-Leveling-Links-Raising-the-Rear-of-the-RSV
