Marcarl Posted January 22, 2007 #1 Posted January 22, 2007 Has anyone figured out yet how to keep grease on the final drive gear case splines. Took my rear wheel off last week and found them to be totally dry again. What do I need to use to keep grease on these things. Suggestions PLEASE.
Eck Posted January 22, 2007 #2 Posted January 22, 2007 I do mine every tire change ....the wheel is off anyway........
ediddy Posted January 22, 2007 #3 Posted January 22, 2007 Hey Marcarl, I talked to the regional service manager with yamaha and the only thing yamaha says can be done is to grease the splines when you change your tire. He said over time the spinning of the splines throws the grease off them.
Squeeze Posted January 22, 2007 #4 Posted January 22, 2007 Hi, is there a Rubber-Gasket sitting around the Wheel in which the Final-Drive engages ? Check this out, there should be one. Every Time you change the Tyre, clean up the old Grease and put some new in.
Marcarl Posted January 22, 2007 Author #5 Posted January 22, 2007 I changed my tire last spring to an Avon, I'd say at this point it's only 1\2 used. Took my wheel off for maintainance and balance and the splines are totally dry with all the grease nicely spread around on the plastic cover. Now if I was to wait to do this at the next tire change it would be running dry for a long time, question is at this point how long has it been dry already. So my question then would be: has anyone ever taken the rear wheel of and found actual grease on the splines? and if so what did you use and how slow do you drive or do you normally just walk beside it? And yes my rubber is in place.
Snarley Bill Posted January 22, 2007 #6 Posted January 22, 2007 Marcarl said: Has anyone figured out yet how to keep grease on the final drive gear case splines. Took my rear wheel off last week and found them to be totally dry again. What do I need to use to keep grease on these things. Suggestions PLEASE. go to autozone and get a plastic bottle of disc brake caliper lube.it is a high temp ultra slick and sticky lube containing all the best stuff such as molydenum disulfide ,ptf, and grafite.best you can get for splines.won't sling off comes with a brush and will last you a lifetime.runs about $10.00 a bottle.way cheaper than the honda stuff.made to lube the disc brake caliper pins on cars ,which is a very high temp application that is exposed to all the elements.
Squidley Posted January 22, 2007 #7 Posted January 22, 2007 You have to use a very sticky grease, regular wheel bearing grease just doesn't cut it. Here is a pic of what I use on my bikes, it's a Valvoline synthetic with Moly in it and it works well for me.
Marcarl Posted January 22, 2007 Author #8 Posted January 22, 2007 Thanks Guys, I'll see what I can find Carl
BradT Posted January 22, 2007 #9 Posted January 22, 2007 If you would just drive the bike on the road instead of four wheeling through every mud puddle it may last longer as well. Brad
SilvrT Posted January 22, 2007 #10 Posted January 22, 2007 Marcarl said: I changed my tire last spring to an Avon, I'd say at this point it's only 1\2 used. Took my wheel off for maintainance and balance and the splines are totally dry with all the grease nicely spread around on the plastic cover. Now if I was to wait to do this at the next tire change it would be running dry for a long time, question is at this point how long has it been dry already. So my question then would be: has anyone ever taken the rear wheel of and found actual grease on the splines? and if so what did you use and how slow do you drive or do you normally just walk beside it? And yes my rubber is in place. It's ever so important to keep that "rubber" in place!
Marcarl Posted January 23, 2007 Author #11 Posted January 23, 2007 BradT said: If you would just drive the bike on the road instead of four wheeling through every mud puddle it may last longer as well. Brad Who? ME?
buddy Posted January 23, 2007 #12 Posted January 23, 2007 Hey Marcarl, I just installed a V-Max final drive,When I went to remove the rear tire and final drive assembly I still had plenty of grease left on the splines,The grease has MOLY,so as long your grease has MOLY you will be covered.. The unit had 7,000 mi before I removed it. If you get it on your hands good luck taking it off its not like regular grease. Buddy
