I have the Custom Dynamics run/turn/brake lights and I'm told that during bright sunlight the turn signals aren't very visible. I'm looking for the Harley license frame (68230-97B) and came across a listing but not sure if it is the right one.
The ad reads :
OEM No: 68230-97B Chrome lamp bar with 4 red bullet lamps, bulb type and license plate backing. Mounts to stock plate bracket. Includes the mount bracket for FLT models without tour pack. The plate included replaces the stock license plate mount plate. For 7-1/4" x 8" plate. Order lamp bar mount plate separately for mounting on pre 2009 models with tour pack. Order license plate holder insert separately. Fits: FLT 1997-2008 UOM: 1 - SET Color: Red Style: Bullet 2011 Catalog pages: 1095, 1101 Suggested to use with #31-1756 lamp bar mount bracket Suggested to use with #42-1533 license plate holder insert
For the 2nd Gen Venture...would this fit and do I also need the mount bracket?
Doesn't look like mine..... with four lights.
Hard to say if it will fit.... Fender may be in way for that chrome bar that holds turn signals?
The one I have has only two lights and bolts right on to license plate bracket...
  • 2 weeks later...
I won a light bracket (68230-97B) on eBay. $125 USD and comes with a HD rack (which I'll sell).
With comments about Custom Dynamics run/turn/brake turn signal not being visible in bright sunlight...I'm considering how to use the light bracket. Thinking I'd like to wire them up as turn signals only (replace lens with clear) and use either incandescent or LED amber lights.
For rear lights I have : (top to bottom)
- trunk wing light (run/brake)
- under trunk light bar (run/brake)
- original brake light
- signal housing (run/turn/brake)
How do you use your HD light bracket? As wired for run/brake? Turn?
Also looking for input - to replace the lens with clear and to go with an LED turn light, what would I need from Custom Dynamics?
http://www.customdynamics.com/harley_davidson_led_turn_signals.htm
http://www.customdynamics.com/harley.htm
