videoarizona Posted July 21, 2016 #2 Posted July 21, 2016 You will need an SWR meter, adapter cables/connectors. You put the meter in line with the antenna using the adapters. Follow the meter instructions...which basically means calibrate the meter then check the SWR ratio with a brief transmit. Adjust the top of the antenna (loosen tiny set screw on antenna coil) and move the top portion of the antenna up or down to get the lowest SWR. On some antennas that are not adjustable, you cut the antenna with snips. Take off the meter and adapters and plug everything back together. That's it... For more info, search this site... Of course if you happen to live near a truck stop that has a CB shop...drive in and let them do it. One word of advice....do not do this in your carport or garage...do it in the open. Works better.
Freebird Posted July 21, 2016 #4 Posted July 21, 2016 You can see this document for complete info. Yes, you need a set of Motorola to PL type adapters to plug into the meter if you are running the stock antenna and base. http://www.venturerider.org/forum/showthread.php?17675-SWR-Meter-and-the-Marshall-Mod
cheny Posted July 21, 2016 Author #5 Posted July 21, 2016 Does it matter if you connect direct to the antenna or do you have to connect in the split from from the black box
Freebird Posted July 22, 2016 #6 Posted July 22, 2016 Plug the cable from the antenna into the SWR meter. Actually the meter will be between the antenna and the black box.
Larry1963 Posted July 22, 2016 #7 Posted July 22, 2016 Go to google, type in ham radio operators in your area, find one close to you, he/she should have all the meters, cables and tools to adjust it. or take to a CB shop
