I got pi$$ed at mine as I think my battery took a dump!! Was fine Saturday, went to take it out Sunday and it wouldn't turn over at all! Took car instead but put battery on charger. Started right up when we got home, but this morning dead again!
Battery is out and now on 2 amp slow charge, I did charge it up again this afternoon and load tested it, didn't look all that good! Sooo, time for another...
Well got the box on top of the airbox and in one last ditch effort moved the bike outside in the sun with the cover off the box so it can bake in the sun being i dont have an oven.. sprayed all the wire connectors and this is what my TCI looks like on the inside.
OK if you know which end of the soldering iron to hold, try resoldering all of those solder connections for the edge connectors (connectors to the wiring harness)...
:think::think::think::think: well ummmm the silver end and which should i use my gun or the iron:rotf::rotfl:so the bourd dont look burnt on Pick Up side...
If you are referring to what looks like somebody puked on the board, that is normal, it's called conformal coating, it is for waterproofing...
PS the gun would be waaaaaay too much heat for that poor lil' board!
In order to tell if the diodes are going you need to see the other side of the board.
There are two ways I know of to get to the other side of the board.
1. Desolder all of the connections to the connectors along the left edge (as viewed in your pic) of the board to remove the board from the connectors. I do not recommend this unless you are really good at working with boards.
2. Make a cut thru the cover just past the connectors so they stay with the board and then just seal the cut line with Black RTV when you put it back together. BE very careful to not cut to deep and cut thru components on the board.
There is a tool made to relax the retaining pins on those available from Pasternak, ($$$) or Field Components, and a couple of others I can't remember names of right now but each pin will have a spring finger which retains it in the plastic connector. Molex makes a lot of that plastic injection moulded stuff and used to sell service tools but don't know if they do any longer. The tool will be segmented to allow more or less attachments, (according to pin count) to make the complete assembly. The suggestion to open the case on the other side is best most likely given the cost of extractor tools which the pins would all need to be done at the same time.
Guest Jamsie
What r high definition mufflers
Sent from my Z812 using Tapatalk
i guess they sound better
sounds like i need a pair for when i start my bike at 930 in the morning and my neighbors ***** about it so i was thinking maybe put some HD mufflers on my bike and set it out by there house and crank her over at 630 :D i have had them ***** about me revving it at 1030 its like well maybe i shouldnt have waited either way you gonna bi#$%:stickpoke::stickpoke:
Today I split the fairing and added another auxiliary plug under the dash. So now I don't have to show the cassette player when I'm using it.
Edited by Skid
Found a pretty slick (in a hillbilly kind of way) mounting for the GPS tablet, an aluminum L bracket sticks with velcro to the back of the tablet and the dash top. doesn't block any info I need on the dash. Easy to remove the GPS, bottom pad, and shut the door. I may a mount so the emblem goes back on the cassette door and it's just like (sun faded) factory.
Put the front Fairing, Dash assembly, Windscreen, Headlight Cover on and took Marie for a ride and adjusted the idle up just a hair... and put the saddle bags trunk and antenna back on called it goodIMG_0026.jpg
Went for a ride! After spending so much time going back and forth around Arizona...finally going to spend some more time in Green Valley and say "HI" to my home.
Got up this AM and it was 71 degrees...yippee...that's riding time!
Noticed desert flowers are starting to bloom from the rain. So had to stop and take the obligatory pic...Nice day!
Well, nothing today but in the past 4 weeks, had the chassis checked over, and it needed to be tightened up, 2 weeks later had coil over shocks installed to replace the leaking air shocks, new air bags, replaced the power port and hazard signal switch replaced, and now waiting on 2 new Shinko 777 tires to be delivered to be installed on the 87. The front tire on the 87 which is practically new is being swapped over to the 93 trike. Next will be carb syncs on both bikes and oil changes.
Nothing on the bike except stage equipment to finish up major service this weekend citing I finally get to remain home. Planning to ride next week. Laid out cut lines to narrow a trailer axle too for my motorcycle hauler.
I reduced the preload on the front springs today. It made the bike handle a lot better but I think there is still more to be had by further reduction in the preload.
