bikerjohn Posted July 13, 2016 #1 Posted July 13, 2016 Just picked up a new 2012 venture with 24000 miles hasn't been rode in a while be rides good. The PO clipped both of the Antennas. And needs a new rear tire Not a bad deal
10spd Posted July 13, 2016 #2 Posted July 13, 2016 Nice ride Sent from my SAMSUNG-SM-G920A using Tapatalk
XV1100SE Posted July 13, 2016 #3 Posted July 13, 2016 Why in the world would anyone cut off the antennas ? Guess they don't know they are worth about $150 EACH !
Great adVENTURE Posted July 13, 2016 #4 Posted July 13, 2016 I put a fabulous set of 3ft flexible fiberglass whips on mine and love them. Search the forums and you should find plenty of info on how to switch them out for $50-$80 dollars.
bikerjohn Posted July 13, 2016 Author #5 Posted July 13, 2016 said his Girlfiend hit them with her legs when she got on the back. I guess she was 8 feet tall
bikerjohn Posted July 13, 2016 Author #6 Posted July 13, 2016 looks nice please send me the info on how you ordered them and how to change them out I am not seeing anyway to disconnect the wire from the end pic\ece.
cowpuc Posted July 13, 2016 #7 Posted July 13, 2016 WOW ZZZZZZZZZZZZZZZZZZZZZZ WOW WOW WOW BROTHER = THAT PUPPY IS GORGEOUS!!:dancefool::dancefool: :ice_congrats-vi6886:ice_congrats-vi6886:ice_congrats-vi6886:ice_congrats-vi6886 to my Texas Hero - you deserve it Biker John!!:thumbsup: Hope it gives you and that precious wife of yours mile and miles and miles of 's!!!
Freebird Posted July 13, 2016 #8 Posted July 13, 2016 You can't disconnect the wires from either antenna. The CB wire is very short. Only goes into the CB which is mounted under the trunk. You just need to pick up a short adapter cable. Some truck stops have them. You need a PL type to a Motorola type because the connection to the CB under the box is the Motorola type plug. For the AM/FM side, you either have to pull the seat, tank, split the fairing and etc. to run a new cable all the way to the radio OR....do what most of us do and simply cut the existing cable somewhere under the seat or something and use some motorola type connectors to splice them.
slowrollwv Posted July 13, 2016 #9 Posted July 13, 2016 You can go to the Venturers.org forum in the tech section. Marshal Gannon did a write up on how to change the antennas and lists what you need to do the job.
Freebird Posted July 13, 2016 #10 Posted July 13, 2016 OR....you can stay right here and get them: http://www.venturerider.org/forum/showthread.php?17675-SWR-Meter-and-the-Marshall-Mod I also got a email from Marshall lately that I've been meaning to add to the tech library but haven't done it yet. Here it is though. Just ignore the part where he calls me an old man. Don, Thanks for updating the MarshallMod data. Had to do a word and PDF file for Venturers Site. Our site went away last year when Deb retired (Partially) on Blue Dolphin Travel site. The Firestik AM/FM are getting almost impossible to find .. The Firefly 3' works just as well or maybe a little bit better than the OEM for AM/FM operation .. Recently I have been working with the tune tip K-40 2' super flex antenna .. Works just as well as the Firefly and in some cases better, because the K-40 is a very thin antenna and does not put as much pressure on the mount. Works awesome on the Goldwing but you will need to get a converter to adapt into the 8mm screw in ... If you want to update the word and PDF files to reflect these upgrades, feel free .. Like to share with all the groups .. Thanks ole man G. Marshall Gammon "Sherriff"
slowrollwv Posted July 13, 2016 #11 Posted July 13, 2016 Sorry Don I didn't know it was on here also.
Freebird Posted July 13, 2016 #12 Posted July 13, 2016 Hey...no problem at all my friend. Just spreading the word.
WildBill1 Posted July 13, 2016 #13 Posted July 13, 2016 said his Girlfiend hit them with her legs when she got on the back. I guess she was 8 feet tall When she swung a leg across one, she was serious. Would liked too have seen her mount and dismount.
