Woops! I'm bad. I'm about to do a clutch job & forgot there's a difference with two cover bolts. I don't remember the location to the two longer cover bolts. Can someone help me out?
Bobby
Thx anyway Don, however between the parts list, service manual, or owners manual, nobody indicates where they go. Grrrrrrr...
The two long ones will stick out of the wrong holes a country mile. Try them in each hole and put them in the ones where they only stick out about 1/2 inch.
Alternatively you can install the short bolts first. If the threads don't grab you've found a deep hole.
  • 1 month later...
