Bobby Posted July 6, 2016 #1 Posted July 6, 2016 Woops! I'm bad. I'm about to do a clutch job & forgot there's a difference with two cover bolts. I don't remember the location to the two longer cover bolts. Can someone help me out? Bobby
XV1100SE Posted July 6, 2016 #2 Posted July 6, 2016 Can't tell you off the top of my head but if you look at the parts diagram it will show you which one is which.
Bobby Posted July 6, 2016 Author #3 Posted July 6, 2016 Thx anyway Don, however between the parts list, service manual, or owners manual, nobody indicates where they go. Grrrrrrr...
MiCarl Posted July 6, 2016 #4 Posted July 6, 2016 The two long ones will stick out of the wrong holes a country mile. Try them in each hole and put them in the ones where they only stick out about 1/2 inch. Alternatively you can install the short bolts first. If the threads don't grab you've found a deep hole.
XV1100SE Posted July 6, 2016 #5 Posted July 6, 2016 Thx anyway Don, however between the parts list, service manual, or owners manual, nobody indicates where they go. Grrrrrrr... You are right....the parts diagram isn't very clear... bolt 27 part # 91314-06025 qty 7 bolt 28 part # 91314-06035 qty 2 - the longer of the two (indicated by 06035) The parts diagram appears to show bolt 28 at a position of 2 o'clock but doesn' show where the second one goes. I would expect it would be around 10 o'clock....but that would be my guess. I didn't do my clutch but someone else did so I couldn't say exactly where the second one goes.
Alsbar Posted August 27, 2016 #6 Posted August 27, 2016 10 & 2 o'clock are the long ones. Just did mine. Sent from my iPad using Tapatalk
