Wilzhere Posted June 30, 2016 #1 Posted June 30, 2016 (edited) Guys i need some help..Has anyone used these parts to rebuild a 83 ventures carbs, i dont need the float needles/ seats. just the gaskets. really just the jet block gaskets and 0-rings, all my float bowl gaskets are in good shape. these look identical ....has anyone tried to use these? are they interchangable? 1985 [TABLE=class: cms_table_fTbl] [TR] [TD][/TD] [TD]Yamaha[/TD] [TD]Vmax 1200[/TD] [TD] any ideas? I've tried punching my own gaskets with no sucess, cant find the right gasket material. Must be another YAMAHA trade secret.[/TD] [/TR] [/TABLE] Thanks Wil Edited July 1, 2016 by Wilzhere
Rob Swallows Posted June 30, 2016 #2 Posted June 30, 2016 Guys i need some help..Has anyone used these parts to rebuild a 83 ventures carbs, i dont need the float needles/ seats. just the gaskets. really just the jet block gaskets and 0-rings, all my float bowl gaskets are in good shape. these look identical .... [ATTACH=CONFIG]106007[/ATTACH] 1985 [TABLE=class: cms_table_fTbl] [TR] [TD][/TD] [TD]Yamaha[/TD] [TD]Vmax 1200[/TD] [TD] any ideas? I've tried punching my own gaskets with no sucess, cant find the right gasket material. Must be another YAMAHA trade secret.[/TD] [/TR] [/TABLE] Thanks Wil Try this: http://www.manassashonda.com/kl-carburetor-repair-kits-detail.htm?productid=7921127 Part #1003-0442 about 1/2 way down the page. Rob
yamagrl Posted July 1, 2016 #3 Posted July 1, 2016 Wilz, The ones you showed for the Vmax will likely work. I used these. http://www.ebay.com/itm/361517049733?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT 4 kits about $91.99. The needle and seat are different from ours, but I'm sure they will work but need to be used together. If you wish to change out the needle and seat you will need the #61 cap, #62 oring, #35 net, filter. http://www.partzilla.com/parts/search/Yamaha/Motorcycle/1983/XVZ12TDK/CARBURETOR/parts.html
Wilzhere Posted July 1, 2016 Author #4 Posted July 1, 2016 Thankyou Folks for the info. I see that they work for many years. Wil
