Mcolabella Posted June 23, 2016 #1 Posted June 23, 2016 So I replaced my fuse block because of poor fuse contact, and dash lights going out, so now after replacing the block, soon I as I turn the key on I am getting a wine/whistle through the speakers. not sure why,
Flyinfool Posted June 23, 2016 #2 Posted June 23, 2016 Double check all of your crimps to be sure they are good. Also double check the grounds.
Marcarl Posted June 24, 2016 #3 Posted June 24, 2016 Sounds like something is working. Try disconnecting the fuses as you listen to discover which circuit is causing the issue.
