dkaiser Posted April 14, 2008 Posted April 14, 2008 Hello all, I am in need a of some parts for my 87 VR. I need the left fairing top. I don't need the inner part just the frame, with the speaker hole and such, also the louvered vent for same. I also need one louvered vent for a lower fairing. While I am at it here, can I still get front turn sygnals at the Yammy dealer or am I better off asking here? If anyone can help me out on this I would appreciate it. Thanks http://i190.photobucket.com/albums/z80/dkaiser1963/DSCF2576.jpg D
PEIslander Posted April 14, 2008 Posted April 14, 2008 dkaiser, The panel is available from flatoutmotorcycles.com for $38.00. I didn't check the louvers. I have a right turn signal you can have and the left too, although it is broken. The right one had a small hole which was patched but it doesn't show so if you want them let me know. I could send a picture tonight if you want. Rick:080402gudl_prv:
dkaiser Posted April 14, 2008 Author Posted April 14, 2008 Hi Rick, I have some that work, they are just chipped. If i am going to replace, it will be with some that are excellent shape. D
bikenut Posted April 15, 2008 Posted April 15, 2008 I got the fairing top last year at the local dealer so maybe you can still get the vents also form the dealers. Bikenut:confused24:
GigaWhiskey Posted April 15, 2008 Posted April 15, 2008 All of those parts are still available through Yammy. Just picked up 5 of the 6 vents. Gotta wait for the sixth one, that one is high high high. 1 of 26H-2837X-00-00 - GRILL, air outlet 3 @ $44.79ea. 1 of 26H-2837Y-00-00 - GRILL, air outlet 4 @ $44.79ea. 1 of 26H-2837V-00-00 - GRILL, air outlet 1 @ $44.79ea. 1 of 26H-2837W-00-00 - GRILL, air outlet 2 @ $44.79ea. 1 of 54K-2172Y-02-00 - GRILL, side cover 2 @ $82.83ea.You might some of these a few bucks cheaper.
dkaiser Posted April 19, 2008 Author Posted April 19, 2008 dkaiser, The panel is available from flatoutmotorcycles.com for $38.00. I didn't check the louvers. I have a right turn signal you can have and the left too, although it is broken. The right one had a small hole which was patched but it doesn't show so if you want them let me know. I could send a picture tonight if you want. Rick:080402gudl_prv: Thanks for telling me about Flatout. The vent is $50, I'll wait on theat and get the panel for now, I can pop the vent in later. D
MiCarl Posted April 20, 2008 Posted April 20, 2008 Check out http://www.cheapcycleparts.com They have those upper cowls (the part that goes on top of fairing and holds speaker) for $33. I haven't priced the other parts as I only need the cowls.
Condor Posted April 20, 2008 Posted April 20, 2008 Just about everything your looking for is available on Ebay. Not all at once, but give it some time and you'll find it.... and a lot cheaper. Just be picky about condition...
cmiles3 Posted April 20, 2008 Posted April 20, 2008 I've got some vents, and a panel that's been repaired. Can't get to them until the end of June. Send me a PM if you're still interested then.
