PTT Button
sdive
Okay since I got the bike in the fall of 05 and the novelty oy listening to the CB wore off (quickly) I haven't used the CB,now 38000 km later one of the guys that rides with got a Vision and we tried talking to each other but my Ptt button doesn,t work we had to communicate via my wife on the back. I sprayed contact cleaner in (from outside) no change,do I have to take it all apart and clean or replace anything and will anything fall apart when I remove the housing.
Ron
Did you follow the wireing cable " from " the handle bar Switches, to a Pull Apart
Plug. Wires for the " PTT ", " Dimmer Switch " , and " Horn Switch " go thru this plug. It should be located, behind the Head light.
After the PTT signal goes thru this plug, it then goes to another Plug located withing a few Inches of the Main CB UNIT.
Either of these two plugs, might have a bad connection.
I would think the one located by the CB unit itself is the culprit.
I have found a couple of loose wires at crimps of the pins on this plug.
See, Page 8-41 and 8-42 of the Service Manual, for the Wireing diagrams, and Wireing Color Codes.
