a while back my friend bought this bike I rode it and it was fine.
but some time back someone repainted it and it was sharp looking
up until now. as who ever painted the bike did a nasty bondo or patch job on the tank.
it is bubbling where the work was done and leaking gas. well it is weeping right now. but behind that peeling paint is rust
where a dent or the old badge emblems where?
we do not believe we can fix this. so he is looking for a gas tank
if any one knows where he can get one please let me know
ebay has a few but the prices are out of this world. some as high as $400 and need work?
thanks
oldgoat
Hey Goat,, another alternative is sealing the tank.. I had to do a number of tanks throughout the years and can tell you from experience this stuff:
http://www.ebay.com/itm/Red-Kote-Quart-Coat-Gas-Oil-Diesel-Fuel-Tank-Sealer-Liner-Patch-Hit-Miss-Engine-/131533413846?hash=item1ea0009dd6:m:m_t7zDtTPyVjhKTiiBBgucg&vxp=mtr
Is the best of the best!! Far better than Kream Koat (the white stuff) - this stuff will actually make a tank within your old tank.. Very very little prep work necessary - if you read on the label you will even see where you can apply it right over rust - they arent joking,, it works that good!! I found it years ago when I was in a radiator shop and they were using it commercially... Good stuff!!
might look into that as I have done the cream coat and it worked but you had to be fast
or it started to set up quick.
can this also be used on the out side where the rust is inside that dent they patched up?
Yep,, should work fine!!!
Puc I see that this stuff stays flexible. Putting bondo over it may cause an air pocket. I guess I will find out though, I just ordered a can for my sons Sabre.
