Lug Nut Posted May 10, 2016 Author #26 Posted May 10, 2016 Not having to worry about that spring is a BIG relief. My mechanic buddy said we could weld something to the bearing to pull it out with a slide hammer (has done before on Harleys). Install we will try to make something to push with equal force. Love this site and roadstarclinic.com......so much info....
rbig1 Posted May 10, 2016 #27 Posted May 10, 2016 (edited) Well you brake the outer bearing and remove the balls. Then lube up the gear put a weld across the bearing when it starts to cool should just pull off by hand. Then have a frydaddy with cooking oil in it hang bearing in oil making sure its not touching bottom. Cook for three min should just slip right on but you have to be quick. Make sure you have all your ducks in a row. When bearing cools it don't move. My biggest question is if bearing comes out with gear alone put on before reassemble. If it wont go in case put in dri-ice then assemble. Done this a million times on equipment. WELL after looking at the pics again looks like the only way to do this in the case you might not want to do. Edited May 10, 2016 by rbig1
Lug Nut Posted May 21, 2016 Author #29 Posted May 21, 2016 Ready to start working on it this week finally got the new bearing....been busy with other stuff unfortunately
Lug Nut Posted May 25, 2016 Author #30 Posted May 25, 2016 Broke loose case bolts, removed half moon retainers....just waiting on my giant 55mm socket to arrive...
ChurchBuilder Posted May 25, 2016 #31 Posted May 25, 2016 I think I used a giant crescent wrench Sent from my XT1254 using Tapatalk
yamagrl Posted May 26, 2016 #33 Posted May 26, 2016 ...just waiting on my giant 55mm socket to arrive... Can't ya just put a 30 and a 25 in the blender and come up with something pretty close to a 55?
Lug Nut Posted May 26, 2016 Author #34 Posted May 26, 2016 Got the nut off easy as pie....BUT I noticed a chunk/dent in the edge of the nut....so I'll order another one now....
Lug Nut Posted May 27, 2016 Author #35 Posted May 27, 2016 Drained the oil, installed a magnetic oul drain plug...haul g bike to friends shop...gonna weld some bolts on and use a slide hammer and yank it out....
Lug Nut Posted May 27, 2016 Author #36 Posted May 27, 2016 10 minutes to remove bearing in the bike...no need to pull the engine. Came out easy, tapped back in.....now just buttoning everything back up....I took pictures...will post later
Lug Nut Posted May 27, 2016 Author #37 Posted May 27, 2016 http://i429.photobucket.com/albums/qq14/sbojrab/Mobile%20Uploads/20160527_102826_zpsp7mkx2jr.jpg[/url Welded nuts on face of bearing, threaded in some long bolts http://i429.photobucket.com/albums/qq14/sbojrab/Mobile%20Uploads/20160527_103042_zpsrdv693p5.jpg Used small puller to gently remove bearing. I did break loose the case bolts BUT this thing came out so easy not sure if you would have to do that http://i429.photobucket.com/albums/qq14/sbojrab/Mobile%20Uploads/20160527_103629_zpsj7ndt1mc.jpg Gently tapped back in with a hammer, used side of bearing puller for this, gently all the way around. Did not freeze the new bearing and no grease applied....went in nice and even. http://i429.photobucket.com/albums/qq14/sbojrab/Mobile%20Uploads/20160527_104532_zps7nexleme.jpg All put in....not a bad job at all of you have a welder and a puller.
ChurchBuilder Posted May 28, 2016 #38 Posted May 28, 2016 That's awesome! I had my doubts. That saved a ton of work Sent from my iPad using Tapatalk
