PO let my bike sit for a while and rust up.. couldn't get the hard bags opened or off but eventually with a lot of spray lube and prying (& banging) got them off and open. Key wouldn't rotate all the way to lock the bags closed or actuate the bar to open so the bag covers wouldn't latch closed. Took the lock covers apart (10mm plastic cover, then little rectangle metal cover with small Phillips screws. Clean the rust, spray, lube (used anti-seize), & on assy they work fine unless the etal plate Phillips screws are snuggled tight.. do I assemble with those screws loose? Seems weird..
At one time I had a post in here with pics of cleaning those lock slides up with pics,, cant find it for the life of me.. Anyway, gotta agree with Dan - dont remember leaving the screws loose - sounds to me like you got something a little out of place or something under the slide. I would take it back apart and check it so it, you dont want them slackers falling apart inside and let you down at the wrong time..
  • 1 month later...
