Black wing Posted April 26, 2016 Share #1 Posted April 26, 2016 so i have an ignitech ignition i was running in my 86 but i now have a 91 and want to use it but not certain if it will just hook up without modding the harness for the single versus dual pick up Link to comment Share on other sites More sharing options...
cimmer Posted April 27, 2016 Share #2 Posted April 27, 2016 The wiring is also different. the 86 uses 4 pickups the 90-93 use a single one. You should be able to reflash the unit if you have all the software that was sent with the Ingitech unit. I have a unit for a 91 and am looking for the cables for an 86-89 unit, maybe we can work out a trade. Let me know. Rick F. Link to comment Share on other sites More sharing options...
Black wing Posted April 27, 2016 Author Share #3 Posted April 27, 2016 sounds like a plan i'll message ya later next week to set up the trade Link to comment Share on other sites More sharing options...
cimmer Posted April 27, 2016 Share #4 Posted April 27, 2016 works for me... Link to comment Share on other sites More sharing options...
dna9656 Posted August 1, 2016 Share #5 Posted August 1, 2016 OK guys I have the software but thought all I needed a USB cable, I can't find the one Gary sent of course...is there something special for the Ignitec I got from Gary? He programmed it for my 83.5 which is sadly no longer capable of running... Link to comment Share on other sites More sharing options...
Patmac6075 Posted August 1, 2016 Share #6 Posted August 1, 2016 I believe it needs to be usb to a serial connector. You should be able to find one at newegg or any computer hardware store (probably not at a Best Buy store, although they could order it) Link to comment Share on other sites More sharing options...
Black wing Posted August 1, 2016 Author Share #7 Posted August 1, 2016 (edited) i have a copy of the disk if you want me to send you the file Edited August 1, 2016 by Black wing Link to comment Share on other sites More sharing options...
yamagrl Posted August 1, 2016 Share #8 Posted August 1, 2016 I have the latest (as of Sept 2015) software from Dingy. It has the files for 83-89 and 90-93 If anyone needs it PM me with your email and I'll send it out. YG Link to comment Share on other sites More sharing options...
Black wing Posted August 1, 2016 Author Share #9 Posted August 1, 2016 (edited) here are all the files from 2013. looks like it has all the maps and set ups http://www.filedropper.com/download_button.png file upload storage Edited August 1, 2016 by Black wing Link to comment Share on other sites More sharing options...
Flyinfool Posted August 1, 2016 Share #10 Posted August 1, 2016 (edited) never mind................ Edited August 1, 2016 by Flyinfool Link to comment Share on other sites More sharing options...
Flyinfool Posted August 1, 2016 Share #11 Posted August 1, 2016 I can open and read the instructions. I can see the list of Ignitec files but I can not download them. Link to comment Share on other sites More sharing options...
yamagrl Posted August 1, 2016 Share #12 Posted August 1, 2016 (edited) Here is the latest that Dingy had in Sept 2015. They are more recent than what came on the cd in 2013 Because some internet security software will prevent downloading EXE files Dingy sent the program file out as a RENAME file. Step Number 1 Convert/rename the 140905a_tcpi4A_V88.RENAME to 140905a_tcip4A_EXE This is a simple operation. Create a folder and name it Ignitec Files. You can do this on your desktop. Right Click any open space on your desktop and select NEW then select Folder then name it Ignitec Files. If you have trouble naming the New Folder don't sweat it "New Folder " will work fine for what we are doing. Just don't forget what it is. Now click and download this 140905a_tcpi4A_V88.RENAME and save it to your new folder named "Ignitec Files" Right click on the file you just downloaded and select Rename You can type in the new name 140905a_tcip4A_EXE or simply change the .RENAME to .EXE Step Number 2 Click and download the Instructions for loading program into TCI and then follow Dingy's instructions. Step Number 3 Click and download the appropriate file for your bike Be sure to save all of the downloaded files to the same location . This is where you will look for them when loading the program 83-89 Venture - V88 program.ign 85-89 VMax - V88 program with V-boost.ign 85-89 VMax - V88 program.ign 90-93 Venture - V88 program.ign Printed Instructions that Dingy enclosed with the Ignitec TCI in 2013 Edited August 2, 2016 by yamagrl Add printed instructions Link to comment Share on other sites More sharing options...
Black wing Posted August 1, 2016 Author Share #13 Posted August 1, 2016 wow the map is way different between the old and new versions Link to comment Share on other sites More sharing options...
KISA Posted August 3, 2016 Share #14 Posted August 3, 2016 Most likely it will not work. You can stitch only the ignition map. You cannot stitch logical part of the program. Also to you having had to change wires. You can be helped only by Ignitech ( Link to comment Share on other sites More sharing options...
yamagrl Posted August 3, 2016 Share #15 Posted August 3, 2016 Most likely it will not work. You can stitch only the ignition map. You cannot stitch logical part of the program. Also to you having had to change wires. You can be helped only by Ignitech ( This is what Dingy sent to me last year. I have not updated mine yet because I have been happy with the performance performance of the program that Dingy loaded during the group buy. I do plan to load the new program and ignition files soon. I'm off next week so I will likely do it then and I'll post about my result and my opinion about the update. Dingy's instructions says how to load the new program so I'm presuming it the updated files will work with the TCI's that he sold to us. @Black wing have you loaded it yet? What are the results? Link to comment Share on other sites More sharing options...
Black wing Posted August 3, 2016 Author Share #16 Posted August 3, 2016 results are bad for the moment, but my bike is not liking either map. see this thread for exact trouble shooting ive done so far. http://www.venturerider.org/forum/showthread.php?122487-ignitech-v80-not-firing Link to comment Share on other sites More sharing options...
