  • Replies 201
  • Created
  • Last Reply
Top Posters In This Topic
Well @Yammer Dan , I appreciate you posting your list. It allowed me to compare where I'm at. The following are the only things that I don't have yet. Not sure I'll do them all but here it is:
Baron's brake reservoir mounted tach (must have sooner or later)
SpeedoHealer (will do at some point)
Galfer SS Clutch line (someday. 2" over)
Flanders Bars (someday)
Barnett SS Throttle cables (someday 2" over)
VMAX Rear End (not sure yet, maybe someday)
Sonic Front Springs (when I need them. That is a lot of work)
No Bubs for me thank you. I got a set of Bubs with the bike. Traded them for a set of OEM RSTD mufflers like were on the '99 when you go it. Has the Harley mufflers on it now and they are LOUD. I'll enjoy them for a while and then put the RSTDs on it.
Yea, he really does a good job on these. I'm going to back spray those under the fairing soon. Just waiting on a couple of things before I split the fairing so I only have to do it once. When I have it apart, I'll remove those clear deflectors and paint them black on the backside.
By the way, the OEM clean lower deflectors wouldn't have been around too much longer. The brackets were cracked about halfway on both of them.
OK...added just a little more...but this is it...no more. :) Polished stainless lower wind deflectors and brackets from @slowrollwv
Yur headlight looks like it has rocks in it and the headlight divider looks funny. Is it just me?
No rocks. :) The bike had Trucklite HID's in the headlight and passing lights when I bought it. I have no idea what they should look like but they seem to work OK.
