mbova Posted April 19, 2016 #1 Posted April 19, 2016 So I'm changing my stator and pulled the cover and a bunch of light brown liquid came out of the case. Is that fouled oil or gear fluid, and should I be worried?
bongobobny Posted April 19, 2016 #3 Posted April 19, 2016 Was it foamy sort of like a milkshake? If so, yes you have problems with water getting into the oil. Was it thin and looked like dirty brake fluid? If so your clutch slave cylinder is leaking and needs to be replaced...
Wizard765 Posted April 19, 2016 #4 Posted April 19, 2016 Your stator is cooled with engine oil so having oil in that compartment is normal. If you didn't drain the oil before you started then you would lose a substantial amount when you cracked the case.. If it is older it could be brown.. if it has water in it then it usually would be foamy or creamy.. It could be fine and normal. Before you put it back together make sure you clean (very well) the area where the rubber grommet goes and the wires come out of the case..then use a good sealant. They tend to seep oil if not sealed really well. I would also recommend a new crush washer for the bottom hole of the middle gear cover.. for me the hardest part was getting the old gasket cleaned off.. like it was baked on.. I used gasket remover which sort of melted it.. Next hardest part was getting it all lined up fighting the magnets to get it back together.. just be patient ,,
mbova Posted April 19, 2016 Author #5 Posted April 19, 2016 It was definitely creamy. I'm waiting on the starter clutch to come in before I put it back together.
Flyinfool Posted April 19, 2016 #6 Posted April 19, 2016 Creamy and looks like chocolate milk is water/antifreeze in the oil. This is a critical thing that must be found and fixed. The engine and transmission share the same oil so whatever is in one is also in the other.
bongobobny Posted April 19, 2016 #7 Posted April 19, 2016 My first thoughts, defective water pump, or less likely head gasket..
Venturous Randy Posted April 20, 2016 #8 Posted April 20, 2016 Or the twinky between the cylinders. Randy
cimmer Posted April 20, 2016 #9 Posted April 20, 2016 The trick to getting the stator cover back on is to get some threaded rod the same size as the bolts and cut them long enough to use as guides so that you can tread it into the bolt holes in about 3 places and then slide the cover on and install the bolts in the remaining holes and then remove the threaded rod and install the remain bolts. This was the strong magnets cant move the cover around on you as you are aligning it up. Rick F.
mbova Posted April 20, 2016 Author #10 Posted April 20, 2016 The trick to getting the stator cover back on is to get some threaded rod the same size as the bolts and cut them long enough to use as guides so that you can tread it into the bolt holes in about 3 places and then slide the cover on and install the bolts in the remaining holes and then remove the threaded rod and install the remain bolts. This was the strong magnets cant move the cover around on you as you are aligning it up. Rick F. Thanks I'll try that.
mbova Posted April 20, 2016 Author #11 Posted April 20, 2016 My first thoughts, defective water pump, or less likely head gasket.. How is do I know if it the water pump
bongobobny Posted April 20, 2016 #12 Posted April 20, 2016 Hmmm, that pretty much involves draining the cooling system (GREAT time to flush the cooling system) and inspect the water pump around the ceramic main seal for signs of "milkshake" around it, may be hard to detect as the coolant will tend to wash it clean.
