Semi-retired Posted April 17, 2016 #1 Posted April 17, 2016 Can anyone point me to the thread on wiring up the "OEM" trunk wing/light? I know it's in the forum SOMEWHERE......cause I read it here 150 years ago. (Well, OK, a COUPLE of years ago!) I seem to remember there are at least two ways to connect this baby (other than the way mine is now.....with all three(?) wires dangling in space under my seat.) One way has the light function as just a running light, the other makes it work with the brake. (I think there might be a little resistor involved on the end of one of the wires for THAT set-up.) Anyone? Anyone? Thanks, guys. I promise to bookmark it this time! Mike
Freebird Posted April 17, 2016 #2 Posted April 17, 2016 Here is a link. Not sure if it's the one you are looking for. http://www.venturerider.org/forum/showthread.php?510-Yamaha-Trunk-Spoiler-Installation
M61A1MECH Posted April 17, 2016 #3 Posted April 17, 2016 (edited) Rather than using that mickey mouse set up in the picture to connect the wires, I would use one of these. https://www.venturerider.org/forum/showthread.php?137711-Aux-lighting-harness-for-2nd-gen-ventureBut that is just me. Edited July 12, 2019 by M61A1MECH
MikeWa Posted April 23, 2016 #4 Posted April 23, 2016 I agree go with Steve's adaptor. It is a much better and easier installation. Mike
Guest divey Posted July 12, 2019 #5 Posted July 12, 2019 Rather than using that mickey mouse set up in the picture to connect the wires, I would use one of these. http://www.venturerider.org/forum/photopost/showproduct.php?product=4&title=aux-lighting-harness-for-2nd-gen-venture&cat=18 But that is just me. Steve this thread is a bit old but the link to your harness is no longer valid. I too need to wire my trunk wing and the instructions with the unit work fine for taillight only, but not brake light. Does your harness ensure the brake light will activate as well as the taillight on the wing? If so I’ll send you a PM to order one. Thank you. Doug
M61A1MECH Posted July 12, 2019 #6 Posted July 12, 2019 Steve this thread is a bit old but the link to your harness is no longer valid. I too need to wire my trunk wing and the instructions with the unit work fine for taillight only, but not brake light. Does your harness ensure the brake light will activate as well as the taillight on the wing? If so I’ll send you a PM to order one. Thank you. Doug OK I fixed the link, in my original post. Yes my breakout harness will ensure brake and tail light functions, as long as the lights in the wing have both functions. Doug, included your mailing address in the PM and I will get one right out to you.
Guest divey Posted July 14, 2019 #7 Posted July 14, 2019 OK I fixed the link, in my original post. Yes my breakout harness will ensure brake and tail light functions, as long as the lights in the wing have both functions. Doug, included your mailing address in the PM and I will get one right out to you. Steve I just sent you a PM. Thanks....Doug
M61A1MECH Posted July 14, 2019 #8 Posted July 14, 2019 Steve I just sent you a PM. Thanks....Doug PM Read and replied to, parts will on the way Monday.
Guest divey Posted July 23, 2019 #9 Posted July 23, 2019 Can anyone point me to the thread on wiring up the "OEM" trunk wing/light? I know it's in the forum SOMEWHERE......cause I read it here 150 years ago. (Well, OK, a COUPLE of years ago!) I seem to remember there are at least two ways to connect this baby (other than the way mine is now.....with all three(?) wires dangling in space under my seat.) One way has the light function as just a running light, the other makes it work with the brake. (I think there might be a little resistor involved on the end of one of the wires for THAT set-up.) Anyone? Anyone? Thanks, guys. I promise to bookmark it this time! Mike Mike I realize this thread is a bit old but were you able to figure out the wing connections so that the brake light would come on? I've just tried hooking mine up (new wing light Yamaha OEM) as per the instructions and the light comes on fine but not the brake light. The instructions and connections are as follows: Red and orange spliced into the red coming from the wing. The spliced red has a resistor on it. Instructions have the red going to the brake wire (yellow) and the orange going to the running light wire (blue). Black to black for ground. Connections all appear to be sound. What am I missing here? Anyone?? Thanks....Doug
M61A1MECH Posted July 24, 2019 #10 Posted July 24, 2019 Those instruction sound backwards to me, if I am understanding what I read. The tail light power should go through the resistor to dim it slightly. The brake power should go directly to the LEDs on the wing so they light up at full power. If the brake power goes through the resistor then you will never see it, because the tail light is over powering it.
Guest divey Posted July 24, 2019 #11 Posted July 24, 2019 Those instruction sound backwards to me, if I am understanding what I read. The tail light power should go through the resistor to dim it slightly. The brake power should go directly to the LEDs on the wing so they light up at full power. If the brake power goes through the resistor then you will never see it, because the tail light is over powering it. Thanks Steve. I’ll try hooking up the brake wire to running light wire on the bike and vice versa. Doug
Semi-retired Posted July 24, 2019 Author #12 Posted July 24, 2019 Mike I realize this thread is a bit old but were you able to figure out the wing connections so that the brake light would come on? I've just tried hooking mine up (new wing light Yamaha OEM) as per the instructions and the light comes on fine but not the brake light. The instructions and connections are as follows: Red and orange spliced into the red coming from the wing. The spliced red has a resistor on it. Instructions have the red going to the brake wire (yellow) and the orange going to the running light wire (blue). Black to black for ground. Connections all appear to be sound. What am I missing here? Anyone?? Thanks....Doug https://www.venturerider.org/forum/attachment.php?attachmentid=117155 I have to admit I haven't "gotten around" to working on this project yet......but, as I remember the old post (from the way-back machine....LOL) I believe the resistor was the "end of the chain". That is, I THINK the resistor actually swung in the breeze......was only connected on ONE SIDE....and the OTHER side was not attached to ANYTHING. I think it was Freebird who sent me the original wiring diagram/instructions.....so maybe I can count on him to jump in here, to "confirm or deny". :-)
Guest divey Posted July 24, 2019 #13 Posted July 24, 2019 I have to admit I haven't "gotten around" to working on this project yet......but, as I remember the old post (from the way-back machine....LOL) I believe the resistor was the "end of the chain". That is, I THINK the resistor actually swung in the breeze......was only connected on ONE SIDE....and the OTHER side was not attached to ANYTHING. I think it was Freebird who sent me the original wiring diagram/instructions.....so maybe I can count on him to jump in here, to "confirm or deny". :-) Mike, see Steve’s reply above. He thinks the instructions might be incorrect (their wires might be crossed as it were). I’m going to try connecting the brake wire to the tail light wire and vice versa and see if that is the fix. I’ll post my results. Doug
Freebird Posted July 24, 2019 #14 Posted July 24, 2019 It is certainly backwards. The resister should absolutely be in the wire going to the tail light. Brake light does not go through the resister. Swap those and you should be good to go.
Guest divey Posted July 25, 2019 #15 Posted July 25, 2019 Those instruction sound backwards to me, if I am understanding what I read. The tail light power should go through the resistor to dim it slightly. The brake power should go directly to the LEDs on the wing so they light up at full power. If the brake power goes through the resistor then you will never see it, because the tail light is over powering it. Many thanks Steve for your observation on this. In fact the instruction sheet that comes with the wing light from Yamaha is incorrect (same instruction sheet that @Freebird posted in this thread a couple years ago). Instructions say Red from wing to Yellow on bike, Orange from wing to Blue on bike, Black to Black. Correct instructions should be Red from wing to Blue on bike, Orange from wing to Yellow on bike, Black to Black. When it comes to electronics, I'd make a good sheep herder so I sure do appreciate the assistance. Don, not sure if you can change the instruction sheet link that you had posted but sure as heck, someone else will run into the same problem should they come across one of these wing lights to install. Thanks.......Doug
M61A1MECH Posted July 25, 2019 #16 Posted July 25, 2019 Good deal, I love it when a plan comes together.
Freebird Posted July 25, 2019 #17 Posted July 25, 2019 Many thanks Steve for your observation on this. In fact the instruction sheet that comes with the wing light from Yamaha is incorrect (same instruction sheet that Freebird posted in this thread a couple years ago). Instructions say Red from wing to Yellow on bike, Orange from wing to Blue on bike, Black to Black. Correct instructions should be Red from wing to Blue on bike, Orange from wing to Yellow on bike, Black to Black. When it comes to electronics, I'd make a good sheep herder so I sure do appreciate the assistance. Don, not sure if you can change the instruction sheet link that you had posted but sure as heck, someone else will run into the same problem should they come across one of these wing lights to install. Thanks.......Doug I didn't change the sheet but did add a note regarding this issue.
