kapebretoner Posted April 15, 2016 #1 Posted April 15, 2016 Any body know where I can buy glass fuses online for a 89 venture royale. Can't get them in ml local area.
yamagrl Posted April 15, 2016 #2 Posted April 15, 2016 Ebay http://www.ebay.com/itm/100PCS-5X20MM-GLASS-QUICK-FAST-BLOW-FUSES-TUBE-AUTO-CAR-0-2A-15A-/322043803241?hash=item4afb4e7669:g:cMAAAOSwHxVW66Wj I also think I have seen them in Walmart
Flyinfool Posted April 15, 2016 #3 Posted April 15, 2016 Another great reason to convert to a new ATM fuse box. What happens if you need a fuse while on the road and you can not find one? The glass fuses and their holders are also a very well documented source of electrical gremlins on these bikes.
10spd Posted April 15, 2016 #4 Posted April 15, 2016 Another great reason to convert to a new ATM fuse box. What happens if you need a fuse while on the road and you can not find one? The glass fuses and their holders are also a very well documented source of electrical gremlins on these bikes. I can't remember. Doesn't one of the members sell a kit to replace the old with the new? Sent from my SAMSUNG-SM-G920A using Tapatalk
yamagrl Posted April 15, 2016 #5 Posted April 15, 2016 Skydoc http://www.venturerider.org/forum/photopost/showproduct.php?product=59&title=first-gen-vr-fuse-box-upgrade-kit&cat=17
kapebretoner Posted April 15, 2016 Author #6 Posted April 15, 2016 thanks yamagrl. ordered some on ebay
djh3 Posted April 16, 2016 #7 Posted April 16, 2016 Another great reason to convert to a new ATM fuse box. What happens if you need a fuse while on the road and you can not find one? The glass fuses and their holders are also a very well documented source of electrical gremlins on these bikes. EZ fix. Wrap a piece of chewing gum wraper around the blown fuse and your good to go.
Yammer Dan Posted April 16, 2016 #9 Posted April 16, 2016 And keep a bag of Marshmallows to toast while bike burns!!! LOL!!! The tin foil repair is good if you get caught out somewhere but bears watching!!
bongobobny Posted April 16, 2016 #10 Posted April 16, 2016 Saw the head off of a 6mm bolt and insert...
syscrusher Posted April 16, 2016 #11 Posted April 16, 2016 Lots of photos and info in this thread: http://www.venturerider.org/forum/showthread.php?105380-Easy-How-to-Fuse-Box
djh3 Posted April 17, 2016 #12 Posted April 17, 2016 LOL yea buddy. I sure hope nobody takes this as serious fix. What I had done in past was I had some sort of old car, I sure dont remember what it was. but I took a glass fuse, knocked the glass out, soldered in a wire and a couple spade connectors a AGC or whatever fuse would sit in. Then a zip top bag with a couple common sizes 5,10 15 amp AGC fuses. Then if the glass fuse blew, I could plug the glass ends in slots and install the AGC "temp" fuse and get where I was going.
videoarizona Posted April 18, 2016 #13 Posted April 18, 2016 LOL yea buddy. I sure hope nobody takes this as serious fix. What I had done in past was I had some sort of old car, I sure dont remember what it was. but I took a glass fuse, knocked the glass out, soldered in a wire and a couple spade connectors a AGC or whatever fuse would sit in. Then a zip top bag with a couple common sizes 5,10 15 amp AGC fuses. Then if the glass fuse blew, I could plug the glass ends in slots and install the AGC "temp" fuse and get where I was going. Now that is a great idea!!
djh3 Posted April 18, 2016 #14 Posted April 18, 2016 Oh I had a pick up that I use to pull a race car trailer with. It developed a short in the wiring and would occasionally pop the fuse for the tail lights. I bought a circuit breaker and wired it in the same way. Then if it happened to pop the breaker I could reset and still have lights and no ticket. I did finally rewire the trailer and the problems went away.
