I'm looking to replace the starter on my 86 VR. Since I have to pull the radiator I was wondering what seals I need to buy, if any.
I did not have to pull my radiator to get to the starter. just pull the mounting bolts and there is enough give in the hoses to get to the starter. You will likely have to remove the thermostat housing to get room to pull the starter out of the case. There are several O-rings that seal that up. I would replace all of them that you open up.
Do they make a simple, replacement seal kit or do I need to order each individually? This is my first rodeo working on my bike. Where's the best place to order.
When it comes to small parts like o-rings and such, I always try the local stealer first. If you tell them what bike it is for they will say they do not have it. If you look u p the part number and just ask for that then they might have it in stock or can order it. When it comes to stuff like O-rings, I try to stay OEM. the 3 cents you save by substituting is not worth the hassle of possibly have to redo it with the right part.
I have never seen an O-ring kit, I always ordered them individually.
