sho_greg Posted March 15, 2016 #1 Posted March 15, 2016 How easy is it? Anyone have a written plan? I'd like to do it with a drain and fill.. taking very little apart.. I also want a cushiony feel.. so what viscosity oil? Thanks for help...
M61A1MECH Posted March 15, 2016 #2 Posted March 15, 2016 Most everything you will need for tis bike is in the technical library section. here is a link to the library http://www.venturerider.org/forum/forumdisplay.php?14-Second-Gen-and-Royal-Star-Technical-Library-READ-ONLY! Here is a link to changing the fork oil. http://www.venturerider.org/forum/showthread.php?57207-Changing-the-Fork-Oil
djh3 Posted March 16, 2016 #3 Posted March 16, 2016 ITs not to bad. Bike on a lift or jack. Remove front wheel as there are a couple bolts up in the fork under where the axle bolt goes you have to remove to drain the oil. I went up one weight on the fork oil. I think 5w is OEM, I went with 10w syn from cycle gear. Its a bit teadiuos getting the fluid in. I used a syringe to measure.
BratmanXj Posted March 16, 2016 #4 Posted March 16, 2016 I went to 10 weight BelRay Synthetic. I used a might-vac with the collection cup to refill my front forks. Put the lower bolt back in and pull the schrader valve. Hook up the Vac pump and fill the (measured) collection cup. Pull 2 psi of vacuum, invert the cup and slowly release the pressure and it will suck the oil into the front forks. I figure if the front forks can handle 7psi of pressure it shouldn't have and issue with 2 psi of vacuum, seals are still good 2 yrs later.
sho_greg Posted March 16, 2016 Author #5 Posted March 16, 2016 So how much fluid in each fork? And I don't have mighty vac.. can I just pour fluid in?
BratmanXj Posted March 16, 2016 #6 Posted March 16, 2016 1. A mighty-vac can be had from Harbor Freight or Amazon for $40 2. You can rig up a tube and funnel system to feed into the schrader valve, but that's going to be a slow process.
sho_greg Posted March 17, 2016 Author #7 Posted March 17, 2016 Syringe? How difficult? I got some amsoil fork oil. Want to dr as in it this weekend, but nervous about getting it back in.
BratmanXj Posted March 18, 2016 #8 Posted March 18, 2016 Syringe? Large syringe like you would use when injecting a marinade into meat. Most have a screw-in needle that you wouldn't need in this instance, as the "tip" alone should be small enough to fit inside the schrader valve.
crowrod Posted March 18, 2016 #9 Posted March 18, 2016 So how much fluid in each fork? And I don't have mighty vac.. can I just pour fluid in? 553ccs=18.70 ounces. Use a squeeze bottle and a hose with a big enough id to fit over schrader valve.
sho_greg Posted March 19, 2016 Author #10 Posted March 19, 2016 Thanks for the replies-- Will give it a shot in a few.. Finally dropped bike off to get carbs worked out.. Fork oil when it comes back.
djh3 Posted March 20, 2016 #11 Posted March 20, 2016 Remember you need to leave some air bleed space when installing the fluid. I used a syringe, a tube slightly smaller than the hole, so air can escape as you are introducing fluid into the fork. Just have to go slow.
