sho_greg Posted February 29, 2016 #1 Posted February 29, 2016 I can't remember if the noise is normal.. changed stator and changed mounting bolts to a allen cap style.. wondering if the head may be to tall..
etcswjoe Posted March 1, 2016 #2 Posted March 1, 2016 Does it sound like a buzz? If so one or more of the bolts are loose.
sho_greg Posted March 1, 2016 Author #3 Posted March 1, 2016 I will have to take some video... might be normal.
Flyinfool Posted March 1, 2016 #4 Posted March 1, 2016 There have been some people that replaced the stator bolts with ones that are a bit to long so that they bottom out in the hole and are not actually tightening down the stator. I am not sure just how long the heads would have to be to hit the inside of the flywheel.
sho_greg Posted March 1, 2016 Author #5 Posted March 1, 2016 Anyone remember length of stator bolts? Can't find the originals... guess I'm going to open it back up..
etcswjoe Posted March 1, 2016 #6 Posted March 1, 2016 (edited) Anyone remember length of stator bolts? Can't find the originals... guess I'm going to open it back up.. A member smarter than me shared that the part numbers translate to the size on most screws and bolts, the stator screw part number is 98507-06035-00 so the "06" is 6mm diameter the "35" is 35mm long. Edited March 1, 2016 by etcswjoe
sho_greg Posted March 1, 2016 Author #7 Posted March 1, 2016 Thanks.. makes sense... have another question, what kind of replacement bolts did every one use... I put cap style stainless Allens with red locktite in (they may have been 30mm in length), and everything was good for a little while, then it all went to pot...
etcswjoe Posted March 1, 2016 #8 Posted March 1, 2016 I ordered new stock ones, I had the screws come loose when I replaced my first one (that is how I knew about the buzz) I either did not let the Loctite cure or I did not clean the holes out good enough. I cleaned the holes out and waited 24 hours before I reassembled everything and good to go.
sho_greg Posted March 2, 2016 Author #9 Posted March 2, 2016 Here is a sound clip... wasted 3 hours going back onto stator. Then still had noise... what was I thinking... who knows the sound? https://youtu.be/WsBfybSGeh4 .
