There have been some people that replaced the stator bolts with ones that are a bit to long so that they bottom out in the hole and are not actually tightening down the stator. I am not sure just how long the heads would have to be to hit the inside of the flywheel.
Anyone remember length of stator bolts? Can't find the originals... guess I'm going to open it back up..
A member smarter than me shared that the part numbers translate to the size on most screws and bolts, the stator screw part number is 98507-06035-00 so the "06" is 6mm diameter the "35" is 35mm long.
Edited by etcswjoe
Thanks.. makes sense... have another question, what kind of replacement bolts did every one use... I put cap style stainless Allens with red locktite in (they may have been 30mm in length), and everything was good for a little while, then it all went to pot...
I ordered new stock ones, I had the screws come loose when I replaced my first one (that is how I knew about the buzz) I either did not let the Loctite cure or I did not clean the holes out good enough. I cleaned the holes out and waited 24 hours before I reassembled everything and good to go.
