Lug Nut Posted February 25, 2016 #1 Posted February 25, 2016 Where can I buy some touch up black engine paint for my 2002 Yamaha Royal Star Venture Midnight? I am very detail oriented and see a couple of spots i would like to touch up. Thanks
Condor Posted February 27, 2016 #2 Posted February 27, 2016 You might give Krylon semi-flat black a try. Should match the finish of the engine very well....
Karaboo Posted February 29, 2016 #3 Posted February 29, 2016 I used stove black (used to paint cast iron wood stoves) on my 650 Heritage. I just did the cylinders and they ended up matching the case and heads almost perfect. I don't know if it is the same black as yours, though. I've never had a bike that new.
SilvrT Posted February 29, 2016 #4 Posted February 29, 2016 isn't Black ... Black ?? ... I mean, if it's not Black, then it's some other color ... right? Any high-heat engine black should work ... as long as it isn't some other color.....
Kiwiroyale Posted March 1, 2016 #5 Posted March 1, 2016 isn't Black ... Black ?? ... I mean, if it's not Black, then it's some other color ... right? Any high-heat engine black should work ... as long as it isn't some other color..... As an ex printer... Unfortunately there are a myriad of shades of the " colour " black, problem is, most are simply called...black!! I like detail too, but black over black in a different manufactures "tint" will be different. Yeaup I know, that was useful...
SilvrT Posted March 1, 2016 #6 Posted March 1, 2016 As an ex printer... Unfortunately there are a myriad of shades of the " colour " black, problem is, most are simply called...black!! I like detail too, but black over black in a different manufactures "tint" will be different. Yeaup I know, that was useful... kinda like WHITE .... LOL
Lug Nut Posted March 1, 2016 Author #7 Posted March 1, 2016 I bought POR 15 engine paint....had great luck with POR 15 rust preventative in the past
