Mad Dog Posted February 20, 2016 #1 Posted February 20, 2016 Looks easy enough but the pin isn't lining up correctly, so I thought I'd ask for the instructions. I did read the other posts and I am headed out to check it again. Just figured having the instructions wouldn't hurt! TIA
Mad Dog Posted February 20, 2016 Author #2 Posted February 20, 2016 Just to clarify, I did bend the rod a bit and it works fine... I guess I'm just being anal... Thanks again
Guest divey Posted February 20, 2016 #3 Posted February 20, 2016 FWIW, my pin never lines up exactly. I have to reach underneath and give the end of the rod a little persuasion with my finger to line it up. Doug
Carbon_One Posted February 21, 2016 #4 Posted February 21, 2016 I've found that due to slight variations the rod is rarely straight when inserting the rod into the frame tabs. It's really not a problem and actually a benefit as it tightens the adapter to the frame. Proper instructions: turn handle forward (level), then bend the rod enough to get a slip fit for the left side tab (kickstand side), turn handle 180* so its facing rearward. That should tighten the adapter to the frame. Larry
Mad Dog Posted February 21, 2016 Author #5 Posted February 21, 2016 Perfect... thats what I thought. Works great I've found that due to slight variations the rod is rarely straight when inserting the rod into the frame tabs. It's really not a problem and actually a benefit as it tightens the adapter to the frame. Proper instructions: turn handle forward (level), then bend the rod enough to get a slip fit for the left side tab (kickstand side), turn handle 180* so its facing rearward. That should tighten the adapter to the frame. Larry
