ap4840 Posted February 1, 2016 #1 Posted February 1, 2016 I'm brand new to this site and would love some input. I was in a hurry last night and was attempting to change my passing lamps from the standard bulbs to LED's. Well, I started disconnecting and connecting the new lights WITHOUT disconnecting the battery.....well long story short I shorted out my headlight fuse, replaced that fuse got the headlight working again.....but the passing lamps still won't work at all. I'm wondering if there is an inline fuse maybe hidden somewhere? I have a 2009 Venture S with the factory passing lamp setup. The LED's did work briefly before stopping....now the old lights won't work either so I've eliminated the lights being defective. I've checked all the main fuses and they appear to be working now. Any advice would be greatly appreciated. Thank you in advance!
Freebird Posted February 1, 2016 #2 Posted February 1, 2016 Yes, they come with an online fuse. Per factory instructions, it is usually inside the faring so you will likely have to split it to find the fuse. Many of us put that fuse in a more accessible place when we installed the lights.
eusa1 Posted February 1, 2016 #3 Posted February 1, 2016 if they were Yamaha / dealer installed there will be a glass fuse at or near the aux power port on the inside of the fairing, clutch side.
djh3 Posted February 2, 2016 #4 Posted February 2, 2016 if they were Yamaha / dealer installed there will be a glass fuse at or near the aux power port on the inside of the fairing, clutch side. If your lucky the holder is still in tact. On my other computer I have pictures of mine. UGLY melted distorted I was surprised it still worked.
ap4840 Posted February 2, 2016 Author #5 Posted February 2, 2016 Thank you so very much for the help! I will split the fairing this weekend and keep my fingers crossed that is all that I messed up! You guys are awesome!!!!! Sent from my iPad using Tapatalk
Bert2006 Posted February 2, 2016 #6 Posted February 2, 2016 You should also take a look at were the wires come down from the fairing to the lights on the steering head. They are known to get caught up in the steering stops and then get cut and or shorted as they get compressed. Here is a write up I did on this a while ago. http://www.venturerider.org/forum/showthread.php?85002-Shaffed-wire
XV1100SE Posted February 2, 2016 #7 Posted February 2, 2016 You should also install a relay and feed power to the battery (with inline fuse). If too much draw on the ignition circuit it will cause problems in the future. You connect the relay to the headlight wiring (see write up) so you can turn on the passing lights : anytime; with low beam only; with high beam only. I have mine wired so I can run them any time. http://www.venturerider.org/forum/showthread.php?43898-Passing-Lamp-Installation
Larry1963 Posted February 2, 2016 #8 Posted February 2, 2016 I'm brand new to this site and would love some input. I was in a hurry last night and was attempting to change my passing lamps from the standard bulbs to LED's. Well, I started disconnecting and connecting the new lights WITHOUT disconnecting the battery.....well long story short I shorted out my headlight fuse, replaced that fuse got the headlight working again.....but the passing lamps still won't work at all. I'm wondering if there is an inline fuse maybe hidden somewhere? I have a 2009 Venture S with the factory passing lamp setup. The LED's did work briefly before stopping....now the old lights won't work either so I've eliminated the lights being defective. I've checked all the main fuses and they appear to be working now. Any advice would be greatly appreciated. Thank you in advance! Safety step 1. Disconnect the battery before doing any maintenance on any electrical component
WildBill1 Posted February 2, 2016 #9 Posted February 2, 2016 I agree inline fuse blown. Tip, take care with removing chrome piece on outer faring tabs are easily broken especially when they are cold. You can warm it slightly with a hair dryer before attempting removal.
ap4840 Posted February 3, 2016 Author #10 Posted February 3, 2016 Update: I CAREFULLY split the fairing this evening and was able to locate the inline glass fuse.....Blown! Thank Goodness! Easy and cheap fix. Thanks again to all for the help. I Greatly appreciate the advice and guidance! Sent from my iPad using Tapatalk
djh3 Posted February 3, 2016 #11 Posted February 3, 2016 Update: I CAREFULLY split the fairing this evening and was able to locate the inline glass fuse.....Blown! Thank Goodness! Easy and cheap fix. Thanks again to all for the help. I Greatly appreciate the advice and guidance! Sent from my iPad using Tapatalk OK sport glad you found the reason they dont light. BUT do you know why it blew the fuse? A relay is the way to go. While LED will not draw as much power, a relay is just a safe way to wire it up.
ap4840 Posted February 3, 2016 Author #12 Posted February 3, 2016 Thanks, I'll go ahead and look into putting a relay on while I have it taken apart.....I guess I'll check with the dealer for a relay for the passing lamps? I don't have much experience with relays. The other option is to keep a sealed halogen bulb that is a little stronger than the Wagner lights that I have had installed I guess...... Sent from my iPad using Tapatalk
Woody Posted February 3, 2016 #13 Posted February 3, 2016 Thanks, I'll go ahead and look into putting a relay on while I have it taken apart.....I guess I'll check with the dealer for a relay for the passing lamps? I don't have much experience with relays. The other option is to keep a sealed halogen bulb that is a little stronger than the Wagner lights that I have had installed I guess...... Sent from my iPad using Tapatalk the dealer is not going to have the relay, I got mine at Radio Shack. since you have seen how the great people of this site came forward to help you and now that you have experienced the vast knowledge of this site consider becoming a supporting member and become a part of the greatest family on the net.
XV1100SE Posted February 3, 2016 #14 Posted February 3, 2016 When I wired mine in I put the hot connection to the battery (and then modified to a 6 gang fuse block) and put the fuse under the drivers seat. That way if the fuse goes it is easy to get to. Check out the wiring diagram for how to wire the passing lights. It shows how to connect the relay. You don't need to be an electrician to figure things out with the amount and quality of the write ups on this site.
Guest Jamsie Posted February 3, 2016 #15 Posted February 3, 2016 good tip for those who dont understand electrics.if you can understand the flow of water in a pipe. imagine your wires are pipes and the electricity is water , switches are taps etc
N3FOL Posted April 6, 2021 #16 Posted April 6, 2021 So yesterday, I was so happy to finally ride my ‘07 to work. First time this year after just riding my SVTC due to cold cold temps in the morning. Anyway... I noticed my passing lamps were not working and I had to do something. I really thought it was the fuse, but it turned out to be just a loose contact somewhere between the switch and the fuse holder. I tried my best to secure it with a couple of zip ties and that did the trick. My ride today to work had my passing lamps lit all the way.
djh3 Posted April 7, 2021 #17 Posted April 7, 2021 I EEEEEE Get ride of those guillotine scotch lock POS. Either make a proper connection or use posi-taps. Also watch for pinched wires up under there. The travel lock for forks like to catch them and pinch wires and short. 1
saddlebum Posted April 7, 2021 #18 Posted April 7, 2021 2 hours ago, djh3 said: I EEEEEE Get ride of those guillotine scotch lock POS. Either make a proper connection or use posi-taps. Also watch for pinched wires up under there. The travel lock for forks like to catch them and pinch wires and short. I am pretty sure the fine print say's to be used by U-HAUL operators only ......
N3FOL Posted April 7, 2021 #19 Posted April 7, 2021 20 hours ago, djh3 said: Also watch for pinched wires up under there. The travel lock for forks like to catch them and pinch wires and short. All good so far on pinched wires in the long run.
