Trader Posted January 11, 2016 #1 Posted January 11, 2016 I've searched a bunch of threads...and it from what I'm reading the easiest way is to remove the back sub frame. I've found the main mounting bolts....but what else needs to be disconnected for the sub frame to be removed? I have the bike up on my table lift. Not even sure I HAVE to remove it yet...but its wet around the petcock. It might just be the gasket or even fuel lines...but my luck it will have to come outl
Chaharly Posted January 11, 2016 #2 Posted January 11, 2016 I'll be watching this thread as I'm curious too. I'd like to pull the tank and drop some BBs in it and try to get any rust that may be in there out
Trader Posted January 13, 2016 Author #3 Posted January 13, 2016 Well I guess I figured it out. I removed the obvious bolts and the only things I had to disconnect was some wiring and class air lines. I suppose I could have done more wire disconnects and just moved the entire class pump etc to front while I removed the rear sub frame
