Finally got to install the load equalizer from Big Bike Parts this weekend. It was a challenge to find a good spot to place it but I found a perfect spot under the passenger seat. Had to remove the foam pad from the fender and then was able to stick the equalizer on. Did my wire connections and all is working as it should. :cool10: When using signals the unit does not seem to get more than warm, but with 4way's on it heats up a bit more. Wonder if it would work as a seat warmer for my wife...:whistling: would need to be riding around with 4 way's on though :stirthepot: Here is how it looks installed:
