I always wanted a volt meter on my bike so searching I found that Battery Tender has one that plugs in the pig tail that goes to the battery so I bought it and it works great tells you voltage while running or sitting, I am going to velcro it to the plastic that covers the center of the handle bars so I can see the volts while running.
  Wizard765 said:
Thank your lucky stars you dont live in UK. same item and similar price for the wiring harness
http://www.amazon.co.uk/Battery-081-0157-Disconnect-Voltage-Display/dp/B00TQ3YUMG/ref=sr_1_25?s=automotive&ie=UTF8&qid=1450106449&sr=1-25&keywords=battery+tenders
yes folks , thats a 17$ part for the princley sum of $135
I have that unit and I would be weary of it draining battery on the long term if installed permanently. It is not waterproof either. I use it as a diagnostic tool to check the condition of the battery with bike off, then start her up to see how its charging.
This is the voltmeter that I'm putting on my vstrom. And my buddy has a bunch of bikes and he just ordered a dozen of them and they are going on all of his bikes.
I think around $4.
I bought a cheap little Chinese dvm for my buddies boat and it's off about 0.5v. Also blue digits at night affects night vision. Get red digits. And I'd have it connected to ignition voltage when you turn the bike on... you can always probe the battery too. Lastly it won't accurately show battery voltage while cranking starter like an analog meter will do.
  tufftom4 said:
That is it I couldn't uploaded pictures because my pc is messed up and Microsoft is remotely on it now.
Sent from my SM-T550 using Tapatalk
Microsoft? Did they call you? Then tell you all about how screwed up your system is? SCAM? Did you call them? Where did you get the number?
I hope you have nothing on your PC that has any personal or banking info..
I called them, I installed Win 10 and could not get it to activate some files were corrupt it took the 4hrs to fix the problem and I got the # from the activation window.
