Hey all,
I'm in need of a rear proportioning valve for the rear master cylinder. If anyone could help me out I would appreciate it, I'd like to avoid spending $75 for one....Thanks :)
Brad,
Are you refering to the proportioning valve off of a 1st gen? If so, I also have one that I'll never use along with a junction block to take one line in from the master cilinder and two out (one with the valve to the rear caliper and the other to the front. I also have the metering valve for the left front caliper.
Rick
Thanks Rick, Thom had the valve, but if I find that I need additional items, I'll keep this in mind...Thank you again my friend
Lowell....a boat :confused24:
