Squidley Posted April 6, 2008 Posted April 6, 2008 Hey all, I'm in need of a rear proportioning valve for the rear master cylinder. If anyone could help me out I would appreciate it, I'd like to avoid spending $75 for one....Thanks
Thom Posted April 7, 2008 Posted April 7, 2008 i have 1 send me your addy , will not be able to send it out until wed am. thom
wild hair 39 Posted April 7, 2008 Posted April 7, 2008 i have 1 send me your addy , will not be able to send it out until wed am. thom just a note to say HI,did you get your boat moved,seeyou
Rick Butler Posted April 8, 2008 Posted April 8, 2008 Brad, Are you refering to the proportioning valve off of a 1st gen? If so, I also have one that I'll never use along with a junction block to take one line in from the master cilinder and two out (one with the valve to the rear caliper and the other to the front. I also have the metering valve for the left front caliper. Rick
Squidley Posted April 8, 2008 Author Posted April 8, 2008 Thanks Rick, Thom had the valve, but if I find that I need additional items, I'll keep this in mind...Thank you again my friend Lowell....a boat
