Yesterday during the Veterans Day parade I noticed my right turn signal was not working.
How do you remove the bulb from the front turn signal? I have removed the clear lens and tried to twist the bulb, I also tried to simply pull it and it doesn't budge. I removed the tiny little metal piece that straddles the rubber housing and tried again. Still no luck. I don't want to break the glass off and leave the base. What do I need to do to remove the bulb?
2009 RSV triked.
Thanks Du-Ron, I just figured that out myself. Noted that you have to push hard enough to fear busting the bulb and having the shattered bits embed themselves in your fingers! (smile)
I replaced the bulb (it did have a filament break). However that did not fix the turn signal problem. The four way flasher works, the "running" lights work, the left turn signal works. The right turn signal still does not work, front or back. Anyone have any suggestions/things to look for or check?
Is that a relay or whatever for the turn signals like in a car? Might that be the problem? I checked the service manual and it shows a flasher relay.
All the lights work on 4-way and the running lights work. That eliminates the grounds and bad bulbs. The relay is working or your 4-way wouldn't flash. The right side turn signal FRONT and BACK are not working. The only thing left is the switch.
... Or the wires, wire connections to the switch.
I'm gonna take my nerves to the next level, and try to open up that switch housing and take a look. Wish me luck! I'm guessing there are 40 miles of wires and contacts in that housing!
Hey Larry.....I do live in the south and you're aiming right at the bullseye (smile). I was riding up a four lane road from Spring City to home in Rockwood, TN just a few days ago. An Ideal Plumbing Company truck was behind me for about 7 or 8 miles. I was in the right lane and he was in the left. We stayed that way for that 7 miles or so. When I got to my turn (to the right of course!) as I made the turn I hear this loud horn blast. The plumbing truck had taken that opportunity to switch lanes and of course....no right turn signal from me.
Before you take it apart, go to your local auto parts store get a bottle of contact cleaner with a nozzle on it, stick it in there and spray, then while spraying move the switch back and forth. see if that helps
