Hi all:
Very sorry for posting off-topic here, but hoping someone has experience with this...
Need rebuild parts for an early 1996 Royal Star standard with the 28mm Mikuni carb set. Specifically need diaphragms and O-rings for pilot screws. Cannot find ANY kits for this carb. model - all help appreciated!
John
Just did some carb work on my 1997 with 28mm Mikuni's. Here is my parts list. These carbs are almost identical to the Vstar 650, so many of the rebuild parts work.
Mikuni 28mm Carb rebuild
OEM (Partzilla.com)
  • 3KW-14105-00-00 PILOT SCREW SET $6.33 each (mainly bought for the O-ring you needed as well.)
  • 36Y-14147-00-00 O-RING (Yamaha Motor) $5.03 each (8 needed for the fuel nipple between the carbs. I tried some from autozone, but they leaked)
eBay:
  • YAMAHA K&L CARB CARBURETOR FLOAT BOWL CHAMBER O-RING 18-8996
  • K&L Supply Float Needle 5pk 18-8944
