Hucklecatt Posted October 26, 2015 #1 Posted October 26, 2015 Hi all: Very sorry for posting off-topic here, but hoping someone has experience with this... Need rebuild parts for an early 1996 Royal Star standard with the 28mm Mikuni carb set. Specifically need diaphragms and O-rings for pilot screws. Cannot find ANY kits for this carb. model - all help appreciated! John
Hucklecatt Posted October 29, 2015 Author #2 Posted October 29, 2015 Just as followup I used Sirius Consolidated to find these parts. Diaphragms only at ~$27.00.
brummers Posted October 30, 2015 #3 Posted October 30, 2015 Just did some carb work on my 1997 with 28mm Mikuni's. Here is my parts list. These carbs are almost identical to the Vstar 650, so many of the rebuild parts work. Mikuni 28mm Carb rebuild OEM (Partzilla.com) 3KW-14105-00-00 PILOT SCREW SET $6.33 each (mainly bought for the O-ring you needed as well.) 36Y-14147-00-00 O-RING (Yamaha Motor) $5.03 each (8 needed for the fuel nipple between the carbs. I tried some from autozone, but they leaked) eBay: YAMAHA K&L CARB CARBURETOR FLOAT BOWL CHAMBER O-RING 18-8996 K&L Supply Float Needle 5pk 18-8944
